Author Topic: MOVE OBJECTS FLOOR  (Read 2990 times)
DEAM
MOVE OBJECTS FLOOR
« on: March 29, 2016, 11:50:16 am »
I want to know how to translate the mesh floor without deleting items from the border
I attach a picture to help you understand
thank you
Re: MOVE OBJECTS FLOOR
« Reply #1 on: March 29, 2016, 12:37:26 pm »
Hi!
Thanks for contacting us. Where accurate placement like this is important I recommend that you don't use the generator's Extend X/Y Size to Area mode. Instead you can use the Generator's XY Size parameters to create a patch of floor that's large enough to cover the area and then move and rotate this into position using Max's transform tools. You can then just use the clipping spline as a final step to cut the correct shape, but it won't influence the position or rotation and you can line it up how you like. I've attached an example that uses this idea.
I hope that helps, but if you have any further questions, please let me know.
Many thanks!
DEAM
« Reply #2 on: March 29, 2016, 02:17:23 pm »
thank you
I will try to use this method
Thanks again
