Author Topic: Embedded Spline  (Read 2788 times)
Embedded Spline
« on: April 23, 2022, 02:00:00 pm »
Hi.
Again I have some unusual enhancement requests.
- Embedded Splines:
Sometimes I use predefined Base Splines to create a Style.
Those Splines should not be accessible to the User to prevent errors.
So, it will be very handy if those Splines can be embedded in the Style and hidden in the Base Object dialog. (similar to Segment node behviour when original geometry has been deleted)
- X/Y size and X/Y Radius:
Now, we can use X/Y size to get virtual Linear Spline.
It will be great if you could introduce a similar for a virtual Circular Spline by adding attribute X/Y Radius
Hope those make sense.
Best Regards
« Last Edit: April 23, 2022, 02:37:21 pm by Dragan »
Re: Embedded Spline
« Reply #1 on: April 25, 2022, 02:03:41 pm »
Hi Dragan,
Thanks as always for the suggestions. We'll have a think about if or how that might be possible.
Cheers!
