Author Topic: Paving With 3 Sized on Surface  (Read 3976 times)
CCGI
« on: January 16, 2020, 05:12:32 pm »
I'm looking to create a long driveway 6m wide using 3 sized paving slabs, 15cmx15cm 15cmx20cm and 15cmx30cm all randomised.
The path needs to follow a curved spline and conform to some uneven ground.
Tried numerous methods with no such luck..
I'm happily able to create this with the slabs running in one direction but I need them to run in the other direction.. any tips?
Many Thanks,
Si :)
Re: Paving With 3 Sized on Surface
« Reply #1 on: January 16, 2020, 07:28:21 pm »
Hi.
I add a few parameters.
EDIT:
This was just a quick setup so I did not pay much attention to corners behaviour. Now on the second look, I can see that Corner Vertex Type have an issue. It should work fine in `Reset` mode but corners are not filled up.
I don't have time at the moment to see what is wrong but I`m sure that Itoo guys will solve the issue.
Best Regards
« Last Edit: January 17, 2020, 09:08:59 am by Dragan »
CCGI
« Reply #2 on: January 17, 2020, 10:42:26 am »
Amazing wizardry!
I'd have never have thought to put it together like that!
I see what you mean about the gaps on the corners however.. I've altered my spline to better conform to the curves I need so should work okay for what I need.
Many Thanks,
Si :)
« Reply #3 on: January 17, 2020, 10:47:28 am »
For Itoo Support:
I have simplified Style to see where is the problem with Vertex Corner. External Nested RC seems to work fine.
Please check the Selector:
1. External Nest
2. Normal Nest
« Last Edit: January 17, 2020, 11:16:28 am by Dragan »
« Reply #4 on: January 17, 2020, 11:26:19 am »
@Itoo Support
Here is one with A2S and L1S generators.
L1S have an issue matching the surface.
@Si
You can use a Generator with Nested External RC and if you need Parameters I can rearrange the Style.
« Reply #5 on: January 17, 2020, 11:49:37 am »
For Itoo Support:
1. External Nest
2. Normal Nest
Thanks for reporting.
« Reply #6 on: January 17, 2020, 12:50:47 pm »
@Rokas
So, it`s a possible bug?
@Si
I found 10min to rearrange the Styles.
Now you have to work with 2 RC objects (both contains some parameters).
If you need anything more, please let me know.
Since the Generator will generate a quite number of items it could take some time to refresh, so please be patient.
Best Regards
EDIT:  ::) I have forgotten the attachment!
« Last Edit: January 17, 2020, 02:18:04 pm by Dragan »
CCGI
« Reply #7 on: January 17, 2020, 04:31:16 pm »
Thank you!
What a legend! I used your original RC Style to make it work for what I need but will have a look over the other attachments for sure!
Many Thanks!
Si :)
« Reply #8 on: January 17, 2020, 06:00:50 pm »
Looking great!
Glad to help.
