Author Topic: Viewport RC object looks different when rendered  (Read 5569 times)
atomov
« on: December 23, 2017, 12:21:29 pm »
Hi, I have this strange problem that I've never seen before. I've made a RC object by scattering one segment along a single spline using Linear 1S array. Then I've used that in another RC object as Segment with similar random rotation settings in transform node. When I render it looks different to what I see in the viewport. My RailClone Pro version is 3.0.9. Please see attached images
atomov
Re: Viewport RC object looks different when rendered
« Reply #1 on: December 23, 2017, 01:37:38 pm »
Update:
I've found the solution. It seems that having turbosmooth modifier on base objects with render time iterations ticked and number different to viewport number is the problem. Also, I had to tick "nest" option when using primary RC object inside secondary RC object as segment node. Now everything looks exactly the same when I render.
