Author Topic: Help with curbs presets  (Read 4361 times)
alyosha82
« on: January 16, 2019, 08:40:05 pm »
Hi all,
I've been using one of the "curbs" presets from the library, however with closed splines the result invariably shows a gap. I've looked at the linear arrays in the editor and the setting seems to be set to "scale" so I'm not sure why they don't just scale to fill the length of the spline exactly?
See attached image please
I'd appreciate any advice
thanks
Re: Help with curbs presets
« Reply #1 on: January 17, 2019, 07:43:39 am »
Hi. Please attach Your maxfile so we can check where the problem is.
alyosha82
« Reply #2 on: January 17, 2019, 11:07:13 pm »
scene is attached
it's just the spline and RC element - if you look around the RC element (look around the roundabout specifically) you'll see that every single individual closed segment leaves exactly 1 gap, either big or small
thank you
alyosha82
« Reply #3 on: January 21, 2019, 03:26:54 pm »
Has really noone ever had this issue? 5 days and no answers?:-)
thanks
« Reply #4 on: January 21, 2019, 03:34:04 pm »
I am sorry this took so long to reply.
Thank You for the scene file. Upon inspection I have found that not every segment in the spline has material ID =1, which is used for the curbs. Some segments are ID =7.
Those segments leave empty space.
Hope this helps.
alyosha82
« Reply #5 on: January 21, 2019, 08:04:23 pm »
Well that worked just perfectly, thank you - I wasn't aware this mattered with RC.
Thank you very much!
« Reply #6 on: January 21, 2019, 08:13:06 pm »
That does not really matter for RC in general. It matters for this particular style as MTL ID 2 is reserved for different geometry.
