Author Topic: Railclone curved corners  (Read 2515 times)
IJ2230
« on: September 23, 2019, 03:15:26 pm »
Hello!
I'm training myself to railclone, by doing this bar counter. But I'm struggling with the arcs of my curve as you can see on the picture. Any ideas how I could Fix that?
Thank you in advance,
Martin.
Re: Railclone curved corners
« Reply #1 on: September 24, 2019, 09:09:18 am »
I would suggest you check following posts describing some tricks to handle this issue:
http://forum.itoosoft.com/index.php?topic=1636.0
http://forum.itoosoft.com/index.php?topic=1679.0
IJ2230
« Reply #2 on: September 24, 2019, 09:34:54 am »
Hello, Thanks for your quick answer! I'll check these!
Regards,
Martin.
IJ2230
« Reply #3 on: September 25, 2019, 08:36:21 am »
Sadly, none of these options helps. I guess I have to make this without railclone  :(
The main reason is having a straight part on the inside and a curve on the outside of the counter. At least this is working well for every other parts
« Last Edit: September 25, 2019, 08:39:37 am by IJ2230 »
