Author Topic: Grid facade  (Read 3037 times)
DusanMNC
    • MNC studio
Grid facade
« on: October 22, 2025, 06:41:44 pm »
I am trying to make this facade using rail clone pro. It is a grid with some segments that are missing on the edges, gaps should be also visible between the joint's and the pillars (vertical segments) should be slightly different one from another.
Dusan
Re: Grid facade
« Reply #1 on: October 23, 2025, 10:13:53 am »
Hi Dusan,
To keep the style simple, you could use multiple generators and adjust the corresponding base splines to effectively “stack” them. Please find attached a sample scene that uses X & Y Evenly Inputs. In this example, the segment used for the X Evenly Input has adjusted Padding to create the gap and X Corner inputs are handled using a Conditional Operator that checks the Y Counter. I hope this helps.
