Author Topic: Simple glass fence  (Read 3894 times)
Crayox
Simple glass fence
« on: June 04, 2021, 11:24:13 am »
I'm creating a glass fence with optional distance between each glass. Glass is chamfered so I created a compose for start middle and end part of the glass. If I use scale mode my chamfers are scaled (which is really not a problem but I feel I'm doing it wrong), and if I use adaptive it will put two glass units and then have a gap like in image 2. I'm using an empty segment in evenly to create gaps. Maybe I should use chamfered segment/empty/chamfer mirror to have holes?
I think there's a better way and I'm doing it wrong.
Thx
Re: Simple glass fence
« Reply #1 on: June 04, 2021, 01:21:03 pm »
Hi.
With railclone it is often that You can get same/similar result with many ways.
I would recommend exploring a nested generator option.- make one linear generator with start default end. and plug that generator to a new linear generator.
Practice makes perfect.
Crayox
« Reply #2 on: June 04, 2021, 01:48:36 pm »
Yep, works flawlessly! Thanks!!
Crayox
« Reply #3 on: June 04, 2021, 01:55:29 pm »
Oh and anyway I can make the corners better? This is ok too, since I have an empty element plugged in the corner too, but how do I make one glass go to the edge?
« Reply #4 on: June 04, 2021, 02:01:32 pm »
break the spline
« Reply #5 on: June 04, 2021, 02:04:37 pm »
Here is the start Style so you can play with it...  ;)
« Last Edit: June 04, 2021, 02:16:21 pm by Dragan »
Crayox
« Reply #6 on: June 07, 2021, 08:09:55 am »
Breaking glass makes one element just go over the other. Is there a way to make the kind of corner I sketched? Red is the spline used to make this.
Dragan thanks! That's a pretty cool one but has similar corner to my...so wondering how to make this.
« Reply #7 on: June 07, 2021, 08:18:37 am »
Well, break and move to desired location.
Solving this style in RC would lead to more questions how to solve non 90° angles.
Crayox
« Reply #8 on: June 07, 2021, 08:41:52 am »
I see...I guess I'll just leave them as is then.
Thx
