Author Topic: Surface and A1S problem  (Read 2459 times)
arch3d
    • arch3d.pl
« on: March 09, 2023, 11:04:26 am »
Maybe someone has such problem and know how to fix it. I dont post scene becasue is really complex and i cannot recreate problem in simple scene:(
I have A1S and A1S plugged as a Marker. If i use surface and Marker is in adaptive mode I recieve flipped geometry. If i switch to vertical or stepped works fine.
Is it RC limitation?
Many thanks for help
arch3d
    • arch3d.pl
Re: Surface and A1S problem
« Reply #1 on: March 09, 2023, 01:50:28 pm »
I send simplified version to helpdesk:)
« Reply #2 on: March 10, 2023, 11:06:23 am »
Replied by email.
« Reply #3 on: April 20, 2023, 11:31:56 am »
This happens because a rare combination of the spline and the surface, which causes than banking angle in the marker position is rotated, with Z pointing down.
Unfortunately we cannot find a way to fix it for all cases.
In case that someone has the same problem, the workaround is to add a Transform node with Deform->Override Banking = 0.
arch3d
    • arch3d.pl
« Reply #4 on: April 30, 2023, 05:26:32 am »
Thank you!
Works well
