Author Topic: Translate stepped segment on evenly position  (Read 3112 times)
« on: August 11, 2020, 07:54:43 pm »
Help!!!  ;D
I need to translate segments on the X-fixed side on Evenly positions. With VERTICAL deformed segments it's a no brainer, but I will have a nested generator, which will be composed out of STEPPED/BEND OFF deformed segments.
« Last Edit: August 12, 2020, 08:07:56 am by Dragan »
Re: Translate stepped segment on evenly position
« Reply #1 on: August 12, 2020, 11:00:30 am »
Hi Dragan.
You can put empty space into compose operator. Seems to do the trick:
Regards
« Reply #2 on: August 12, 2020, 11:22:55 am »
Hi Rokas,
Yes, this works but since all this will be part of the more complex macro generator this will make it even more complex  ;). I was kinda hoping that I could solve this just with some arithmetic magic. Never mind, I`ll make quick SubMacro for this.
Thank for the help  :D and...
I desperately need an option to influence Segments Deform Properties in Macro Style. Imagine how much we can make it easier for Users Segment Inputs if we could change those properties "under the hud". Corners Bevel modes, Angled distribution etc.
Please, please, please.....  :'(   ;D
« Reply #3 on: August 12, 2020, 11:40:11 am »
Noted ;)
« Reply #4 on: August 12, 2020, 12:40:01 pm »
Hm... it will work but with small issue. I guess I can not avoid this.
« Reply #5 on: August 12, 2020, 10:09:11 pm »
Got it... Slope Fixing for vertical Segment should be off
