Author Topic: Railclone 2 Crash  (Read 82196 times)
QH2703
Railclone 2 Crash
« on: May 31, 2013, 07:34:23 pm »
I have installed Railclone 2 upgrade - it crashes every time I use it- is there any way to revert to the previous version? - I'm on a deadline and am absolutely f**ked if I can't get this to start working again.
It unhelpfully says this as the error each time:
Caller ID: 22
Error code: 16
Error message: Client connect operation to Named pipe endpoint "\\.\pipe\RCF_40836" timed out after 30000 ms (server not started?).
Subsystem: 0
Subsystem name: No sub system.
« Last Edit: May 31, 2013, 07:36:32 pm by QH2703 »
Re: Railclone 2 Crash
« Reply #1 on: May 31, 2013, 08:04:36 pm »
Yes, you can revert to v1.4.3. Here are the instructions to make a clean 2.0 uninstallation:
http://www.itoosoft.com/forum/index.php?topic=1487.0
You can find RailClone 1.4.3 at the Client Area->Previous Versions.
Anyway, i would like to help to you with the 2.0 issue. Please, write me when you ready to make some tests.
« Last Edit: May 31, 2013, 08:11:15 pm by iToo »
QH2703
« Reply #2 on: June 06, 2013, 08:33:54 pm »
So- every time I create a new object using the  interface after some modifications the properties dialogue pane on the left goes blank. then it crashes and I get this error message.
Caller ID: 6
Error code: 16
Error message: Client connect operation to Named pipe endpoint "\\.\pipe\RCF_21052" timed out after 30000 ms (server not started?).
Subsystem: 0
Subsystem error: 0
« Reply #3 on: June 06, 2013, 10:57:46 pm »
I see in our system that your RailClone license is not activated.
Please, check your license using the License Manager (Start Menu->Itoo Software->RailClone Pro) and send us a screenshot to support@itoosoft.com.
QH2703
« Reply #4 on: June 10, 2013, 07:22:26 pm »
so you have to reactivate the licence when you upgrade- thanks for that help- no idea how to add a screen shot to the forum- do you not have a simpler way to give support?--- this feels like scrawling it on a wall and hoping somebody who knows something is passing by.....
« Reply #5 on: June 10, 2013, 07:54:35 pm »
No, it is not necessary to reactivate the license for upgrades. Checking our logs, i see this is the first time your license has been activated.
About the screenshot, there is a attachment button to upload images and other files. But in this case our request was to send the screenshot by e-mail (to avoid exposing license details publicy).
