Author Topic: Everything's messed up after update to 6.0.8  (Read 3829 times)
nubo
« on: June 28, 2023, 12:55:04 pm »
We've just updated RailClone from 6.0.7 to 6.0.8 and we've encountered many bugs:
1. Most of our existing custom styles and RailClone objects are generated totally different than before:
1.1 Segments are in different order in compose-groups
1.2 Segments are generated in places that they shouldn't be
1.3 All translations within the style are messed up
2. Display preview generation doesn't work, everything displays in mesh mode, changing from mesh to boxes or quick mesh does nothing. The point-cloud preview generates OK.
3. After clicking on render we get a lot of 'display limit' errors - everything was fine before. RailClone objects render with the same issues as in the viewport.
Looks like we have to roll back to 6.0.7 for now.
3DS Max 2023.3.3
Vray 5
Windows 10
FI6242
Re: Everything's messed up after update to 6.0.8
« Reply #1 on: June 28, 2023, 01:56:23 pm »
here too
we went back to 6.0.7 all ok
3dsmax 2024
vray 6
windows 10
« Last Edit: June 28, 2023, 01:57:54 pm by FI6242 »
« Reply #2 on: June 28, 2023, 01:58:55 pm »
I apologize for that.
As you pointed out, there are a couple of bugs in RC 6.0.8 which are causing multiple issues.
We use several complex scenes for testing, but unfortunately were not enough to identify these problems.
We have removed RC 6.0.8 from downloads. Please, continue using RC 6.0.7 meanwhile.
Sorry again.
nubo
« Reply #3 on: June 28, 2023, 03:22:37 pm »
Thanks for the info,
Looking forward to check out the fixed version as soon as you deal with the issues, especially the faster generation of complex styles sounded really promising. :)
Przemek
EstebanAV
« Reply #4 on: June 28, 2023, 05:40:40 pm »
Hi! I had same problems after installing the latest version.
Rolled back to version 6.0.7 and everything worked fine again and will keep it for now. Thanks Itoo team for your efforts to solve it.
« Reply #5 on: June 29, 2023, 01:24:17 pm »
We just published RC 6.0.9 beta, which hopefully should fix the problems of RC 6.0.8.
Point 1, and possibly 3, were caused by a couple of bugs which are already fixed.
But we could not reproduce point 2.
We introduced some optimizations to the Display 'Box' mode which would cause it, but in our tests everything seems fine.
Please, test this build and tell us if you can reproduce the problem. If so, please send a test scene to check it.
« Reply #6 on: June 30, 2023, 01:25:38 pm »
We finally found the bug which was causing problems 2 & 3.
We'll release an update very soon.
nubo
« Reply #7 on: June 30, 2023, 02:25:44 pm »
Wow, that was quick!  :D
Well, I shouldn't be surprised by now.
