Author Topic: Random Objectos from Ceiling generator  (Read 2416 times)
CharlyRT
« on: May 15, 2022, 02:35:33 am »
Hi there, I want to create a Ceiling that has 3 different types of objects, the classic square panel, a panel with a light and a panel with vent and light that its size is the double from the others 2. I want to position them randomly or with some control. Right now i only have 1 of each one.
Here is the File in 3ds max 2020
« Last Edit: May 15, 2022, 02:48:49 am by RTstudio »
Re: Random Objectos from Ceiling generator
« Reply #1 on: May 16, 2022, 01:11:40 pm »
Thanks for the question. I'm not 100% sure of the end goal, but please see the file attached for a possible solution. There are two options you can pick from using the selector operator, either a pattern version that you can create using the Sequence operator, or a random version. If you are able to use the X and Y spline to set the ceiling size instead of a clipping area then I've also added a third option that allows you to use markers on the Y axis to choose the type of tiles.
I hope that helps,
CharlyRT
« Reply #2 on: May 16, 2022, 04:17:34 pm »
wooow, thank u so much Paul!!!
I think this could work for me, thanks again!!!!!
