Author Topic: Export Parameters - bug?  (Read 6424 times)
TL1895
« on: January 19, 2024, 04:19:33 pm »
I've made a simple style and wanted to also export the clipping spline expand percentage.
It seemed to work, but does not work after closing the editor.  Maybe (Probably) I'm doing it wrong.
Any help would be appreciated...
TL1895
Re: Export Parameters - bug?
« Reply #1 on: January 19, 2024, 04:21:45 pm »
Hi!
It looks as though you've wired a Constant node instead of a Numeric. Constant nodes are intended for use in the graph, Numeric in the modify panel.
Hope that helps,
TL1895
« Reply #2 on: January 19, 2024, 05:24:05 pm »
Aaah, yes, thank you so much Paul!
