Author Topic: Export to user interface suggestions  (Read 4150 times)
MN4869
« on: June 01, 2015, 01:11:42 pm »
Would it be possible to expand the part of the RC interface where the numerical parameters appear?
I'm making some detailed components where end users can select from a number of  options for the level of detail they want in their RC. E.g. Tick boxes to enable/disable handrail and drop down to select different types of posts etc
This part of the interface feels very cramped. Would be great if it was bigger or if you could drag it to enlarge.
Also would be awesome if there was another node - similar to numerical but you could add text options in a drop down menu which would select an index number under the hood. So rather  than having post types 0, 1, 2 etc, they would be clearly named 'none', thin, thick etc.
Re: Export to user interface suggestions
« Reply #1 on: June 01, 2015, 04:49:59 pm »
Hi, i'm not sure if Max allows to use resizeable rollouts. I'll investigate if it can be done.
Regarding the drop down parameters: yes, this is something we like to include in next updates.
Thanks for your suggestions.
