Author Topic: Randomize spacing with a fixed minimum distance  (Read 2463 times)
BB5945
« on: August 01, 2022, 02:12:31 pm »
Hi all,
I try to figure out a way to randomize spacing distance between elements but with a fixed minimum distance.
As you can see attached, something goes wrong with the minimum...I guess it's not the right way
Any advice ?
Nicolas
Re: Randomize spacing with a fixed minimum distance
« Reply #1 on: August 01, 2022, 02:17:10 pm »
Hi Nicolas,
You should drive "Override Padding (Left / Right)" values instead of Translation (which just "shifts" the Segment). That should do the trick ;)
BB5945
« Reply #2 on: August 01, 2022, 09:22:47 pm »
Thank you sir :) indeed it works fine this way !
Nicolas
