Author Topic: Expression checking  (Read 21726 times)
arch3d
    • arch3d.pl
Expression checking
« on: February 23, 2025, 10:32:20 am »
I would like to perform checking if XMarkerID is equal to one of values from array: 2,5,8,11,14,17...etc.
Any suggestion how to do it via expression?
if(XMarkerID==............ ,Input1,Input2);
Thanks for any help.
Re: Expression checking
« Reply #1 on: February 23, 2025, 11:40:38 am »
It should work with ValueList.
I don't have access to 3dsmax at the moment to try this:
1. Add ValueList and create your array
2. Export Index parameter for the Value List. Use SegmentXCounter for this index.
3. Use this as Input1 in your expression
« Reply #2 on: February 23, 2025, 11:22:02 pm »
Well, it should work if that is what you need.
I added another RC Annotation to display various data such as Dimensions, Spline IDs, SegmetXCounter, MarkerID values, and Vertices numbers...
Please let me know if you need something more.
arch3d
    • arch3d.pl
« Reply #3 on: February 24, 2025, 07:27:10 am »
Hi Dragan,
Nice to see you again:)
Ill try, but as i think correct in such case I shoud type elements of the list maually, and not expose all nubers form array.
Btw for dimmensionsion i used ceil Operator because i get vaiues from Marker Data.
Many thanks for help!
« Last Edit: February 24, 2025, 07:50:00 am by arch3d »
arch3d
    • arch3d.pl
« Reply #4 on: February 24, 2025, 07:42:55 am »
Miss this reply, yea this shoud work
Many thanks
« Reply #5 on: February 24, 2025, 08:09:53 am »
Ah, yeah... I forgot there is a password on the RC Annotation object. Sorry  ;)
@ everyone pass: topgun
The main staff is the Macro, which generates a number mesh on the output. You can input any number mesh using numeric input, box input is just for the decimal separator.
I have exposed some parameters too...
important note: if you are about reusing some of my macros the main generator must be named "Master"
Please let me know if you need some more info or additions to preset.
« Last Edit: February 24, 2025, 08:15:40 am by Dragan »
arch3d
    • arch3d.pl
« Reply #6 on: February 24, 2025, 08:18:26 am »
Thanks!
And it seems take only first element of array in my case :(
« Last Edit: February 24, 2025, 08:21:22 am by arch3d »
« Reply #7 on: February 24, 2025, 08:28:30 am »
You need to connect the arithmetic operator to the index parameter:
Arithmetic expression:
return
Segment X counter;
« Reply #8 on: February 24, 2025, 08:31:58 am »
You can use Macro for this too, just add my MasterOverrideMarker to Input and set which MarkerData you are using (0-8).
arch3d
    • arch3d.pl
« Reply #9 on: February 26, 2025, 02:52:38 am »
Thank You!!!
« Reply #10 on: February 26, 2025, 06:41:43 am »
 :D  Glad to help
