RailClone => RailClone Pro (*) => Topic started by: Sergey_Dobrij on September 27, 2018, 06:12:32 pm
http://prntscr.com/kzgnxt
Hi, everybody! Tell please what I do not so?
Expression can be correct but RailClone can have other things why it is not building correctly.
Try accepting and build Your style further.
If that does not help, please upload Your scene and we will check it for You.
I study this lesson - https://www.itoosoft.com/tutorials/spider-glazing?back=page%3D4%26tag%3Drc
If I open a scene which is finished. There everything works with this expression. If I do from scratch, then nothing leaves
Please upload Your scene and I will check it for You.
Thank's!
Your arithmetic is not connected to anything.
(https://i.imgur.com/AdDzfx1.png)
Accept error and build Your style further.
Hi!At me doesn't proikhodit construction in a scene (
http://prntscr.com/kzoi4c
Thank's. Understand
If You do get this eror
(https://i.imgur.com/mJtDqJW.png)
Don't use exported segments parameters, but add another Transform operator and export its parameters:
(https://i.imgur.com/5Ug8BBW.png)
Note: And make sure You are not dividing by 0.
Hope This helps
