Author Topic: Expression for matID value  (Read 3243 times)
arch3d
    • arch3d.pl
« on: February 18, 2022, 11:59:39 am »
I would like to ask you for quick help. I hate condition expression and I never know how to use it :(
I have L1S with fixed ID's
Now i would like to offset Generator from spline using expression
If matID=3 would be offset defined as Input1 else  Input 2 would define offset
Many thanks for help
Michal
Re: Expression for matID value
« Reply #1 on: February 18, 2022, 12:04:43 pm »
Switch Arithmetic node to Expression and type:
return
if(XSplinematID==3,input1,input2);
arch3d
    • arch3d.pl
« Reply #2 on: February 18, 2022, 12:08:04 pm »
Thx, now i know where i made mistake:)
« Last Edit: February 18, 2022, 12:09:39 pm by arch3d »
« Reply #3 on: February 18, 2022, 12:14:28 pm »
But I`m not sure this will work on General Y Offset. I think there were issues about this because of offsetting spline under the hood. I don't have Max at the moment to check it out.
If this won't work you can try adding transform and expose Y/Z Translation parameter (depending on your generator orientation) and use it as an offset.
« Last Edit: February 18, 2022, 12:26:16 pm by Dragan »
arch3d
    • arch3d.pl
« Reply #4 on: February 18, 2022, 12:33:32 pm »
Exacly i found this Y Offset limitation
I tested as well
return
if(XSplinematID==3,input1, if(XSplinematID==4,input2,input1));
Your expression and nested second conditional works fine in X and Z Axis.
If General Y Offset wont work ill  transform segments
« Last Edit: February 18, 2022, 12:35:36 pm by arch3d »
« Reply #5 on: February 18, 2022, 12:37:36 pm »
Yeah, I know it  >:( :(
Well, you will have to use either Transform>Translate or some nesting depending on the complexity of your generator.
arch3d
    • arch3d.pl
« Reply #6 on: February 18, 2022, 12:39:36 pm »
I have nested L1S in L1S so its pretty complex - i testet segment translation - works fine
Thx again
