Author Topic: parametric window  (Read 2506 times)
RL1396
parametric window
« on: November 03, 2019, 04:40:07 pm »
I encounter two problems when creating a parametric window.
The first concerns the position of the handle. I would like it in the middle of the left amount but despite its position in the sequence, it does not place properly.
The second is that despite the padding setting, one side of the handle does not appear.
Would you help me?
I would have liked to show you an image but an error occurs when I insert an image in the message
« Last Edit: November 03, 2019, 04:42:45 pm by RL1396 »
Re: parametric window
« Reply #1 on: November 03, 2019, 06:26:01 pm »
Use another Generator for the handle. Connect the handle segment to the Start Bottom or the End Bottom and add a Transform node before to move it to the right position.
If some part of the segment disappears when using padding it is probably because the Slice checkbox is on in Segment>Properties>Deform.
« Last Edit: November 03, 2019, 06:32:46 pm by Dragan »
