Author Topic: Rotate segment using 1s  (Read 2534 times)
Dean
« on: March 31, 2020, 08:47:29 pm »
Hey all,
I have a building with cladding, which is currently vertical.
It's made using a 1s array, and clipping splines, which are animated.
The client wants to show the cladding horizontal too, and I'd ideally like to animate the cladding rotating.
When I rotate the segment, the cladding has gaps. I presume it's spaced using the bounding box?
Here's a screen capture of the problem I'm having...
https://youtu.be/9lzFfQbNSNc
Is there a way to rotate the segment, so the sides of the cladding remain, and the cladding also repeats?
And is it actually possible to keyframe the railclone properties? Just did a quick test, and couldn't tell if it's actually working or not.
Dean
Dean
Re: Rotate segment using 1s
« Reply #1 on: March 31, 2020, 08:54:46 pm »
Max 2019 file, with Railclone 4.1.1 incase it's of use...
https://www.dropbox.com/s/vl7kzlcsppch47l/Cladding_Only_01.max?dl=0
Dean
« Reply #2 on: April 01, 2020, 08:30:04 am »
Hey all,
Hi!
Correct. But You can adjust padding values to shrink/expand that bounding box.
Only using 2d array instead of Linear. Attached example
You can keyframe RC parameters, but only after they are exported fist, like this Z Rotation:
In case You want a deeper RailClone understanding  I would recommend You follow our ongoing series of tutorials. You may also find helpful our detailed documentation.
I would highly recommend you to check our RailClone "Getting Started with RailClone" followed by our "Next Steps with RailClone" guides too.
Dean
« Reply #3 on: April 01, 2020, 12:14:24 pm »
Brilliant thanks, I'll take a closer look.
And yes, going through some tutorials. I'm still very new to Railclone, but getting there!
