RailClone => RailClone Pro (*) => Topic started by: pmac on March 17, 2021, 02:35:46 pm
Title: Extend x/y size to area problem
Post by: pmac on March 17, 2021, 02:35:46 pm
i have problem with using extend x/y size to area. When i have the option checked, i cannot change clipping area mode to exclude or include (it is greyed out) what results in problems with cutting holes in the clipping area. What may cause the problem?
Title: Re: Extend x/y size to area problem
Post by: Rokas on March 17, 2021, 03:45:34 pm
Hi and welcome to the forums.
When You use "Extend to clipping spline" it does just that. No need to set it as include area. You can change hole checking inside the spline with "Hierachy Checking"
This options determines the way that RailClone processes multiple or stacked splines when using Extend X/Y Size mode.
More about this You can read in our documentation page (https://docs.itoosoft.com/railclone/style-editor/2d-arrays-generator-a2s#id-2Darrays-GeneratorA2S-clippingClippingArea).
In case You want a deeper RailClone understanding  I would recommend You follow our ongoing series of tutorials (https://www.itoosoft.com/tutorials?tag=rc&page=1). You may also find helpful our detailed documentation (https://docs.itoosoft.com/railclone).
I would highly recommend you to check our RailClone "Getting Started with RailClone (https://docs.itoosoft.com/railclone/getting-started-with-railclone)" followed by our "Next Steps with RailClone (https://docs.itoosoft.com/railclone/next-steps-with-railclone)" guides too.
Post by: pmac on March 17, 2021, 05:28:10 pm
Hi and thanks for your reply. When switching between different hierarchy options, i still didnt get proper holes. The problem was in the spline, it was rotated before so because of that railclone probably had some problem, i used reset xform on it and now everything works fine. Thanks for your help!
