Author Topic: Railing post offset  (Read 3569 times)
Macker
Railing post offset
« on: June 13, 2016, 06:03:32 pm »
hey guys,
I'm trying to get a set of railings modelled as per the photo, but I'm struggling on the corners...
Any ideas?
Re: Railing post offset
« Reply #1 on: June 13, 2016, 08:01:32 pm »
Please see the attached file for a possible solution. In the end I've solved it be adding the post after the corner in a separate object. This is to avoid the wide base being sliced at the corner. I hope it helps, please let me know if I can help further.
Many thanks!
« Last Edit: June 13, 2016, 09:06:25 pm by Paul Roberts »
Macker
« Reply #2 on: June 14, 2016, 09:46:43 am »
Paul, that's amazing. Thank you ever so much!
