Author Topic: "Extract Tiles" Macro not working with Vray GPU?  (Read 12723 times)
GeraldW
« on: June 18, 2024, 12:21:52 pm »
Hey,
just stumbled upon a strange issue.
I´m using the "Extract Tiles" Macro, which works perfectly fine in VrayCPU.
As soon as I switch to VrayGPU the mapping is ignored. This happens not only at render time, just apply a UnwrapUVW modifier to check.
This is not super important, but I´m curious how this marco is even influenced by the render engine.
Re: "Extract Tiles" Macro not working with Vray GPU?
« Reply #1 on: June 18, 2024, 12:33:04 pm »
This style utilizes the UVW XForm node. In V-Ray CPU, this node is supported with Instancing enabled. However, when using V-Ray GPU, you need to disable the Display > Render > Use Instancing Engine option.
I hope this helps.
GeraldW
« Reply #2 on: June 18, 2024, 02:05:46 pm »
Thanks for your reply and explanation.
Easy fix :)
