Author Topic: Need some help with Hexagon alignment  (Read 5796 times)
Re: Need some help with Hexagon alignment
« Reply #15 on: January 05, 2021, 06:03:42 pm »
Glad to help  ;)
Well, the corners are always a little bit tricky. With your pattern, I will probably prepare/remodel separate segments for the corners inputs but then the generator should be based on L1S nested with some A2S/L1S to fill up the default wall surface. Clipped A2S will be hard to track where to finish with the corner and where to finish with the start/end segment.
IVORM
« Reply #16 on: January 05, 2021, 08:13:20 pm »
Hi Dragan,
Because I’m still a newbie I find it very helpful reading your solution. Is it also possible to keep both splines separate and adjust the height of one spline with a transform node so the pattern match up?
« Reply #17 on: January 05, 2021, 08:33:31 pm »
Yes, of course. You can export  X and Y translation parameters and play for each of the spline individually.
IVORM
« Reply #18 on: January 05, 2021, 08:51:10 pm »
Thks Rokas! You and Dragan are a great help to me. My next question   About facade cladding is on another thread (keeping the forum clean) ;)
