Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
facade decor - managing angle issue
« previous
next »
Print
Pages: [
1
Author
Topic: facade decor - managing angle issue (Read 3933 times)
IJ2230
Newbie
on:
September 12, 2021, 12:07:09 pm »
I'm trying to create a parametric decor for a building façade. It went really easy with a simple line, but as soon as I tried to work with angles to go around the building volume I couldn't find a way to make the angles work properly.
Here is what I'm trying to achieve :
Here are the 3 elements:
Here is my issue:
Any ideas? Thank you very much in advance for your assistance! I'm joining a .max file if that helps.
Last Edit: September 12, 2021, 12:12:44 pm by IJ2230
Logged
ITOOSOFT
Hero Member
Re: facade decor - managing angle issue
Reply #1 on:
September 13, 2021, 09:50:06 am »
Please take a look at the attached file. I made the following changes.
- The RC object was rotated 90 degrees on the X-axis. I set this to 0 and reselected the Spline
- Changed the Segments' Alignment > Z to top. Changed the other axes to automatic.
- Enabled Rules > Bevel Corner and set the BC Offset to 50%
- Change the corner segment so that it was twice as large on the X Axis. This will allow it to bevel on the corners better without leaving fragments of the sides where it is cut.
I hope that helps,
Logged
IJ2230
Newbie
Reply #2 on:
September 13, 2021, 12:52:27 pm »
Hello, thanks for your help! However I think you forgot to add the file. I tried to tweak the settings as you said, it's much better but not exactly what I need. May you send me the file please? Cheers!
Logged
ITOOSOFT
Hero Member
Reply #3 on:
September 13, 2021, 12:55:22 pm »
Oops - You're right. Here it is.
Logged
IJ2230
Newbie
Reply #4 on:
September 13, 2021, 01:04:51 pm »
Almost there, cheers!
Any ideas on how to ensure to have the shape number (1) around both sides of the angles (3),
so the pattern is always 1-2-1-2-1-2-(ect...)
1-angle-1
-2-1-2-1(ect...), as you can see on the 1st image of my first post?
Logged
ITOOSOFT
Hero Member
Reply #5 on:
September 13, 2021, 01:26:32 pm »
That should be possible using a Compose operator in the Corner input. You can then wire 3 to the first input and 1 to the second. Please see attached.
Logged
IJ2230
Newbie
Reply #6 on:
September 13, 2021, 01:32:36 pm »
That is perfect! thank you very much, very helpful! I will practice with it
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
