Author Topic: FS - Mirrored Bevel Mode option  (Read 4648 times)
IJ2087
« on: May 07, 2018, 11:03:09 pm »
We are using RailClone to create a lot of different building types for architectural projects and have a Feature Suggestion. Along with the current Bevel Mode options (None, Reset, Extend, Symmetric) we'd like to suggest a "Mirrored" mode where the corner object gets mirrored in the X direction rather than starting over when crossing the corner. The attached image shows how the current setup works. The "AB" at the corner starts out as "AB" again as it turns the corner. We'd like an option to make it "ABꓭA" instead of "ABAB". This will allow us to create proper corner elements that mirror across the corner, rather than repeat across the corner.
Thanks.
Re: FS - Mirrored Bevel Mode option
« Reply #1 on: May 09, 2018, 03:40:53 pm »
Thank You for this question.
Thing is, Bevel works on default segment (in Your case- 12).
To get effect of mirrored corner element AB You can do it in this configuration:
IJ2087
« Reply #2 on: May 09, 2018, 10:38:10 pm »
Ah yes...The compose node. I've never really tried that much, but it looks like it would to the trick. Thanks.
