Author Topic: How to randomize 4 segments in sequence on X with no visible repetition?  (Read 6367 times)
IvanK
Hi, maybe it's has a very simple solution:
I have 4 segments connected to the sequence node. I thought to randomize not just the counter, but also the counter position because I need to get a long sequence with no visible repetition. But I can't find how
For randomization it would be best to use Randomize node, not Sequence.
Also Selector node with exported Index parameter works well.
Hope this helps.
IvanK
Rokas, thank you very much!!!
DM5847
Re: How to randomize 4 segments in sequence on X with no visible repetition?
« Reply #3 on: February 06, 2024, 12:58:08 pm »
I have a follow up question to this; we are currently trying to build a facade panel system that contains 1m, 0.66m and 0.33m panels. The issue is that we want railclone to randomise the 1m panel with a 0.66+0.33 panel combi (and mirrored) so that we always have a vertical line across the facade every 1 meter. In a "random sequence" you would get 1 - (0.66+0.33) - (0.66+0.33) - 1 - 1 - (0.33+0.66) - 1 - (0.66+0.33) - etc randomly interchanging the 3 options.
I've set up a couple of sequences to create this, however when threading it through a randomize node that seems to override the sequence and just randomise the 3 panels.
Am I missing a setting that I need to turn on so that the randomize node respects the "sequence objects" its being fed?
In de image you can see that righ at the start it's a 0.66m panel with a 1m next to it. If it was following the sequence it would have to be a 0.66+0.33m setup before moving on to a 1m panel.
« Last Edit: February 06, 2024, 01:05:19 pm by DM5847 »
nubo
« Reply #4 on: February 08, 2024, 09:46:55 am »
@DM5847
I think it would be more suitable to use the Compose node and Reverse (or Mirror, depending on the visual effect you want to achieve) node for mirroring the sequence instead of the Sequence node.
See attached.
Przemek
« Last Edit: February 08, 2024, 09:52:36 am by nubo »
