Author Topic: Problem with edges of roof tiles  (Read 10046 times)
raf200
« on: October 30, 2023, 11:37:24 am »
I;m totally newbie with Railclone. I use it time to time in most basic way.
Today I wanted to save some time with roof tiles but in the end I spend much more time trying to fix the issue I met.
I used one of Pantile tiles from stock library. Unfortunately at the edges there are strange artifacts. I was looking for offset parameter to move it a little bit hoping it will solve problem but I couldn't find it. Any help would be very appreciated.
Regards Rafal
PS I use 4.3.2
Re: Problem with edges of roof tiles
« Reply #1 on: October 30, 2023, 02:26:49 pm »
This is because of the verge tiles. You should disable Left and Right verges from the Parameters rollout. Unfortunately though, the versions that are included with the plugin have a small issue caused by a change to recent versions of RailClone which stops these settings from working correctly.
To fix it, please find attached the reworked styles scene (rc_ridge_tiles.max / rc_concrete_tiles.max) -  please use these to overwrite your local copy (by default located under C:\Users\<yourUsername>\AppData\Local\Itoo Software\RailClone Pro\lib\default1\Architecture\Exterior\Roofing\Hips and Ridges\objects / C:\Users\<yourUsername>\AppData\Local\Itoo Software\RailClone Pro\lib\default1\Architecture\Exterior\Roofing\Tiles\objects).
If there is anything else we can help with, please let us know.
raf200
« Reply #2 on: October 31, 2023, 05:55:55 pm »
Thank you very much, worked perfectly :)
HU0164
« Reply #3 on: May 06, 2024, 06:09:15 pm »
Hi, there,
Is it normal to still have the same error with RailClone version 6.1.7?
Why hasn't the library been updated?
« Reply #4 on: May 28, 2024, 08:49:26 am »
I apologize for that. We have identified a problem in our repository, and several files were not properly uploaded to the server.
Please, run Update Manager (from Windows Start menu->Itoo Software). It should download the updated packages.
