Author Topic: Ideas on how to model  (Read 3689 times)
Anthony Lester
« on: December 14, 2015, 05:35:58 pm »
I am trying to model a facade using a 5 different components, the facade is has a cocave curve and there is no reguallr pattern.
Because there is no regular pattern I am resigned to having to build it manually using a collection of 'compose' operators however I having some difficulties.
I thought that I could use the vertical line (hieght of the building) as the xspline and then the curve as a y spline and have the RC rotated 90 thereby having the rows running from bottom to top, I could then uses conditional statements to assign different sequences compose operators to specific y counters.
Needless to say this isn't working and I have got myself rather confused!!!
Any help or advice would be appreciated.
Re: Ideas on how to model
« Reply #1 on: December 15, 2015, 10:22:18 am »
Hi Anthony,
I'm not sure how accurately you have to match the CAD drawings or if a certain amount of randomisation is permissible but either way I would probably tackle this using Sequence operators to assign the segments you need to each row. You can  set the Sequence operator to Increment on Y and then each input represents a row number. If you want to repeat a row you can simple increase the count value.
If you need to control the pattern on the X axis you can also connect sequence operators set to increment on X. I've attached a demo file to illustrate these approaches but please let me know if you have any further questions.
Many thanks!
Paul.
« Last Edit: December 15, 2015, 10:30:49 am by Paul Roberts »
Anthony Lester
« Reply #2 on: December 15, 2015, 11:02:43 am »
Thanks Paul, but unfortunately they are quite specific about the layout. :)
Looks like I am going to have to do everything manually but the the increment on Y is a good tip thanks.
A
