Author Topic: Old Library  (Read 2867 times)
ML2660
Old Library
« on: March 05, 2017, 12:08:32 pm »
In RC 2.7 i noticed there are some new curb types added to the library.
I´d like to use the old ones )don´t know which version they were added.
Maybe you could add the old types again in a new version of RC?
In the new version, there is no geometry added when i choose a concrete curb and a spline added from a dwg file.
When i choose a different type of geometry from the library (like a road), it works fine.
Is there a new method for creating curbs somehow?
Re: Old Library
« Reply #1 on: March 06, 2017, 10:59:26 am »
I would suggest you to check this "Autocad link in max 2016 loses connection on reload" tightly related thread. Your spline has most probably a different Material ID assigned - this style uses Spine's Material IDs to assign different types of kerb (ID 1 normal kerb, ID 2 drop kerb). Assigning the Material ID to ID 1 / ID 2 should fix it.
ML2660
Re: Old Library
« Reply #2 on: March 06, 2017, 07:42:36 pm »
Hi Michael,
Sounds logical, will try this asap.
Thx for the quick reply!
