Author Topic: feature request: keep start/end in Scale mode  (Read 5353 times)
harumscarum
    • harumscarum's portfolio
« on: December 25, 2014, 01:04:11 am »
would be great to have an option keep start and end of segment of its original size in Scale and Count segment modes with certain threshold (like Flat Top/Bottom option for Vertical mode)
this will allow use only one segment for many different window sizes
P.S. Scale Mode work incorrectly (use Count=1 instead)
« Last Edit: December 25, 2014, 01:08:54 am by harumscarum »
Re: feature request: keep start/end in Scale mode
« Reply #1 on: December 26, 2014, 11:28:33 am »
Ok, added to the wishlist.
Please, would you upload a scene with the scale/count problem ? I cannot reproduce it here.
Thanks.
harumscarum
« Reply #2 on: December 26, 2014, 02:01:37 pm »
yes please here is file atached - it looks like that - http://joxi.ru/dp27G8tnadB27n
« Reply #3 on: December 27, 2014, 11:33:32 am »
Ok, i see what happens: when Bevel is enabled in Scale mode, the segment is extended beyond the corner to generate a correct chamfer. This correction is not applied using Count, because this mode is not compatible with bevels.
To fix it, just set Bevel mode to None (or use Count=1).
