Author Topic: RC on Xref object Surface Error  (Read 2434 times)
JK1258
« on: March 17, 2022, 04:38:07 pm »
I am using max 2021 + RC 5.12.
Rc object with Xref object (xref tracks, Xref Modifiers) as a surface crashes max while opening a scene.
It can be created, modifed, rendered and saved. It just won't open.
Best,
Mike
Re: RC on Xref object Surface Error
« Reply #1 on: March 21, 2022, 02:33:55 pm »
Hello Mike,
Apologies for the slow reply. I can't seem to reproduce this here on a simplified scene, are you able to send us a sample file that reproduces the crash? You can send it to us at helpdesk@itoosoft.com.
Many thanks.
« Last Edit: March 22, 2022, 10:33:25 am by Paul Roberts »
JK1258
« Reply #2 on: March 22, 2022, 10:25:07 am »
Ok,
I had to try few things.
Scene with Xref object is linked as a xref object with only one surfface selected.
Also the same scene is liked as a Xref scene.
This way that surface is a double xref - once as an object, once as a scene.
Regards,
Mike
« Reply #3 on: March 22, 2022, 10:50:25 am »
Hello Mike,
Thanks for taking the time to identify the cause of that error. I can reproduce it here now. As you have pointed out, it would appear that referencing the file as a scene and an object is the cause. I'll pass it on to our development team for further investigation.
Thanks again for reporting the issue.
