Author Topic: File open error  (Read 2658 times)
JJ6860
File open error
« on: February 09, 2023, 01:05:49 pm »
hello, I am trying to use models from the libraries but when I load any of them I get the following error,
I have searched for the files and tried to open them independently and I get this error, I have also deleted and redownloaded the files and they seem to download corrupt.
Is there any solution?
only happens to me with the models in the architecture/exterior/fences/metal category.
« Last Edit: February 09, 2023, 01:10:33 pm by JJ6860 »
Re: File open error
« Reply #1 on: February 09, 2023, 03:25:59 pm »
I would suggest you reinstall the problematic package in the following way from the Update Manager:
  • If you cannot see installed packages, Go to the View menu and select Installed Packages.
  • Click on the "i" icon for the package you'd like to remove (the Metal one in your case).
  • From the Details Dialog, click Uninstall.
  • Hit the Install button at the bottom of the Update Manager.
