Author Topic: Style Editor window disappeared  (Read 11378 times)
theedge
« on: June 05, 2014, 01:54:44 pm »
When I click on "Open Style Editor" button, nothing happens. I think the window might have gone outside the monitor boundary, as it happens sometimes with other max floating windows. Is there some .ini file where the position is saved, so I can reset to fix this ?
Re: Style Editor window disappeared
« Reply #1 on: June 05, 2014, 02:02:45 pm »
Yes. The fix is described here.
In RailClone 2.3.0b we've added a workaround to recover from this issue just reopening the Style Editor.
theedge
« Reply #2 on: June 05, 2014, 02:17:02 pm »
Well,  I do not have this key : HKEY_CURRENT_USER\Software\Itoo Software\RailClone\Style Editor
see attached screen capture
EDIT : tried reinstalling Railclone. No change.
« Last Edit: June 05, 2014, 03:09:51 pm by theedge »
« Reply #3 on: June 05, 2014, 03:13:24 pm »
From your screenshot I can see you are probably looking for it under HKEY_LOCAL_MACHINE instead of HKEY_CURRENT_USER. Please double check you are searching for Style Editor window keys under HKEY_CURRENT_USER\Software\Itoo Software\RailClone\Style Editor.
Kind regards,
theedge
« Reply #4 on: June 05, 2014, 03:17:01 pm »
Ha, yes ! I was in the wrong section indeed.
It's fixed now. Thank you.
