Author Topic: Possible in the current RC?  (Read 3380 times)
ritoo
« on: September 26, 2023, 02:35:30 pm »
Please take a look at this:
there are 60 degree tilted columns that  connect upper and bottom curvy splines (not equal in plan view). Is it possible reproduce in current RC?
https://www.archdaily.com/993188/higher-roch-tower-brenac-and-gonzalez-and-associes?ad_medium=gallery
Re: Possible in the current RC?
« Reply #1 on: September 27, 2023, 09:56:49 am »
As mentioned in this tightly related post by my colleague Paul: "I'm afraid at the moment there's not an easy way to achieve this, RailClone doesn't (yet) have a generator that can create geometry between two parallel splines. However, there are a few workarounds that might be possible. Please take a look at this thread for a similar case. "
Please feel free to watch this related part of July's livestream for more details.
ritoo
« Reply #2 on: September 28, 2023, 09:15:07 am »
Yeah I saw it before - the solution is  rather distant from be called fully parametric. The task is much more cumbersome than not just connecting 2 splines: RC should preserve column's tilt (+\-60 degree), distance between columns and besides there are complex joints at the column ends that  made of 2 correspondingly rotating parts (2 axes).
