Author Topic: Flemish Bond  (Read 2518 times)
manel_reig
Flemish Bond
« on: August 22, 2020, 10:13:38 pm »
I am not sure what I am doing wrong with the flemish bond macro. I attach 3dsmax file
I just want to get the results like in this video of itoo: https://www.youtube.com/watch?v=hbwXVwK4N1E
Also tryed to follow this tips: https://forum.itoosoft.com/railclone-pro-(*)/flemish-bond-brick-pattern/msg18381/#msg18381
1 - The segment's Alignment > Z should be set to Center
(the result is even worst than aliogned "automatic")
2 - Deform > Bend  should be turned Off
(this solved the corners)
3 - The X size of the 1/2 brick should be 50% of the Full brick (this is not automatic)
No diference on behavior regardles the bricks I use on the "Quarter brick" slot and in the video I can see they are using the same segment for the two slots...
So I am very confused with something that aperently is so simple... :o
thank you
Re: Flemish Bond
« Reply #1 on: August 24, 2020, 11:06:06 am »
Please accept our apologies. It would appear a small change in RailClone since this macro was created had caused it to stop working. Attached is a file that contains a working version of the Macro. We'll update the bundled version for the next release.
Please let me know if you have any more questions.
All the best,
manel_reig
Re: Flemish Bond
« Reply #2 on: August 29, 2020, 11:06:04 am »
All the best,
Thank you Paul!
One last question, is there a way to make the "corners" work with the flemish bond and the running bond?
Re: Flemish Bond
« Reply #3 on: August 29, 2020, 01:02:31 pm »
I'm afraid those macros were only designed to work on 90-degree interior and exterior corners. For other angles we'd have to take another looks to see if it's possible. Added to our list for further investigation, thanks for the suggestion.
