Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Floor Herringbone
« previous
next »
Print
Pages: [
1
Author
Topic: Floor Herringbone (Read 14246 times)
Paulo R. Beck
Newbie
Floor Herringbone
on:
March 02, 2014, 12:04:45 pm »
Hello guys!
I was trying to do this floor, however could not distribute properly. Each brick should be 10 cm to the left of the latter. Can anyone give a suggestion?
Logged
ITOOSOFT
Hero Member
Re: Floor Herringbone
Reply #1 on:
March 02, 2014, 08:26:07 pm »
Hi Paulo,
Please find attached a file that should help you to re-create this style. The technique used is the same one demonstrated in the
Parquet Floor tutorial
Many thanks,
Logged
Paulo R. Beck
Newbie
Reply #2 on:
March 02, 2014, 09:38:28 pm »
What an idiot I am! Yes I looked at the tutorials ... only thing was I did not rotate it!
anyway ... thanks!
Logged
ITOOSOFT
Hero Member
Reply #3 on:
March 02, 2014, 10:08:39 pm »
No problem,
glad you fixed it
Logged
IT1371
Full Member
Reply #4 on:
March 04, 2014, 01:15:33 pm »
About that..
In my cases I can't apply the railclone created herringbone because I don't use splines for pavements in my scene.
Most times its and editable poly, and I can't apply railclone for that.
Is there a solution for that?
Logged
ITOOSOFT
Hero Member
Reply #5 on:
March 04, 2014, 03:00:13 pm »
there's not a way at present to add a RailClone object directly to a surface. You should be able to select the boundary edges using the border sub-object mode of any edit poly object and use the Create Shape From Selection tool found in the edit-borders rollout to create a spline that could be used with RailClone.
Logged
SD1975
Newbie
Reply #6 on:
June 19, 2014, 06:45:46 pm »
Is there any way to create a pavement such as in the attached image? It seems as soon as the bounding box of the geometry changes, the whole mathematics behind the pattern don't work any more.
Juris
Logged
ITOOSOFT
Hero Member
Reply #7 on:
June 19, 2014, 07:11:49 pm »
Hi Juris,
This can be achieved in the same way as the herringbone tutorial. I've attached a file for you to look at. It's adapted from the herringbone style that comes with the built in library.
In this case I just adjusted the segment's padding and fixed translation values by eye. No maths required
Hope that helps,
Thanks.
Logged
SD1975
Newbie
Reply #8 on:
June 20, 2014, 12:07:48 pm »
Hi Paul,
Thank you very much for swift reply - no idea why I couldn't work it out yesterday. I've added a bit of math to the pattern and ability to change scale of the tiles without loosing the pattern.
Hope this helps someone.
For some reason my file eneded up over 2Mb, so had to zip it.
Juris
Logged
SD1975
Newbie
Reply #9 on:
June 20, 2014, 12:22:26 pm »
Did the same thing for herringbone pattern - hope this helps others.
I must say you have a great product, albeit with quite a steep learning curve to get to the bottom of it.
Best,
Juris
Logged
ITOOSOFT
Hero Member
Reply #10 on:
June 22, 2014, 05:24:53 pm »
Hi Juris,
Thanks for the kind words about RailClone and for uploading the files, I'm sure others will find those examples really helpful.
You might also be interested in RailClone's built in global scale function, this will allow you to easily resize many RailClone objects. It's found in the Style Rollout:
Though this would give different results from your examples, as it will scale the depth of the tiles as well as the height and width.
Cheers,
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Floor Herringbone
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
