Author Topic: Floor planks  (Read 5690 times)
Darwin Ceballos
Floor planks
« on: October 23, 2014, 01:01:46 am »
Hi! Have managed to stack 3 planks with different width and equal length in an sequence = Ax2 , Bx2, Cx1
All planks has length of 360cm and I just want some randomization offset in X direction. How can I do this?
« Last Edit: October 23, 2014, 01:06:51 am by CQ1888 »
Re: Floor planks
« Reply #1 on: October 23, 2014, 09:55:13 am »
Hi Darwin,
To add some X offset variation you can add a random value to the Left Padding property for the first board in every row. To do this I've used a conditional operator so that if Segment > X Counter = 1 returns true. Then in the True input slot added a Transform operator, connect the sequence operator, exported the left padding and connected a Random number parameter node. In the False input connect just the sequence operator. The finished style should look like this:
I've attached the scene file for you to check out. Please let me know if you have further questions.
Cheers,
« Last Edit: October 23, 2014, 09:57:15 am by Paul Roberts »
Darwin Ceballos
Re: Floor planks
« Reply #2 on: October 23, 2014, 11:57:24 am »
Thank you so much for your help, just what I needed.
Cheers :)
