Author Topic: flooring pattern  (Read 5316 times)
nicobulo
flooring pattern
« on: August 07, 2017, 01:34:15 pm »
Hi guys,
I want to achieve a triangular shaped flooring,
The Railclone settings are pretty simple but I can't manage to get exactly what I want.
I would need the triangles to translate from half of their width every 2 rows but I can't find how to do that.
ANyone has an idea how I could do that ?
Thanks in advance !
Re: flooring pattern
« Reply #1 on: August 07, 2017, 03:15:17 pm »
A possible style set-up would be to use the Sequence Operator in the Increment at Y mode, where even rows will use "shifted" Segment by the Transform - X Fixed Translation (in the attached sample scene automatically calculated from the X Size attribute of used Segment). Attaching a sample scene. Hope that helps.
nicobulo
« Reply #2 on: August 07, 2017, 04:12:05 pm »
Wow, great !
I (almost) managed to achieve it by using 2 A2S, but this is much more efficient,
Thanks !
