Author Topic: Railclone between two splines  (Read 3899 times)
mabulsoud
« on: February 09, 2021, 07:40:07 pm »
Hello. I'm trying to create a stair railing with a variable height.
What I've tried to do is subtract the X.SplineCoords.z of the two splines to get the different height but that doesn't seem to work as I thought it would. Clipping splines are undesirable and don't work due to the stairs turning anyway. Is there a way to create the railclone object *between* two splines?
Marwan
Re: Railclone between two splines
« Reply #1 on: February 10, 2021, 07:31:00 am »
Hi Marwan, unfortunately, only if You create 3rd spline between them.
« Last Edit: February 10, 2021, 07:02:14 pm by Rokas »
mabulsoud
« Reply #2 on: February 10, 2021, 03:28:04 pm »
Hi Rokas,
I'm not sure what you mean. Could you look at the attached file and let me know what you mean by a 3rd spline?
Marwan
« Reply #3 on: February 10, 2021, 04:38:30 pm »
You can add CrossSection modifier to create a new spline in between those two:
I just added few more vertices:
mabulsoud
« Reply #4 on: February 10, 2021, 06:12:36 pm »
Thanks Rokas. I don't understand how that helps with the railclone style. Could you please show me how that works in the railclone style itself?
« Reply #5 on: February 10, 2021, 06:54:35 pm »
I have no idea what are You building. It was not a solution to Your style, just a tip, how to make RC work between the splines.
I understand it might not work for what You have in mind.
It might for some styles though, such as this.
« Reply #6 on: February 10, 2021, 09:46:47 pm »
With the cross-section option, you create a new spline to be used as Base Spline. Now you should reorganize your RC object to use vertical spline segments (for poles) + horizontal with your original splines (for railings).
« Last Edit: February 10, 2021, 10:07:58 pm by Dragan »
