Author Topic: Unused parameter input_memory/speed influence  (Read 2505 times)
« on: July 30, 2023, 11:55:50 am »
Does an exposed parameter not in use affect memory or speed during evaluation?
e.g. exposed parameters are  X Fixed Scale, Y Fixed Scale, and Z Fixed Scale but only X Fixed Scale is connected/used, and the remaining two are not connected.
I`m worried those not-in-use parameters still consume some memory or influence some time in evaluation on VERY LARGE SCALE generators.
Re: Unused parameter input_memory/speed influence
« Reply #1 on: July 31, 2023, 08:06:06 am »
No. If parameter is not connected to any node, performance hit should be negligible.
