Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Herringbone Floor Problem
« previous
next »
Print
Pages: [
1
Author
Topic: Herringbone Floor Problem (Read 13961 times)
philm
Newbie
on:
February 19, 2014, 12:08:54 pm »
Hello
I'm having a problem with the Herringbone parquet tutorial for railclone.
I went through all the steps and I keep getting the error message "invalid base objects".
I've attached the scene, thanks for any help!
Phil
Logged
ITOOSOFT
Hero Member
Re: Herringbone Floor Problem
Reply #1 on:
February 19, 2014, 12:43:55 pm »
Hi Phil,
I've checked out your file and the problem is that you're using an L1S generator, this is designed to create railclone objects that follow a spline in a linear fashion. You need to use the A2S generator that creates the 2D arrays necessary for this type of style. Here's the node tree:
Hope that helps,
Logged
philm
Newbie
Reply #2 on:
February 19, 2014, 05:58:58 pm »
Hi Paul,
Thanks a lot, I got it to work now. Should have read the tutorial more carefully!
Phil
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
