RailClone => RailClone Pro (*) => Topic started by: QM4272 on November 27, 2017, 08:08:06 am
Title: gaps when building components
Post by: QM4272 on November 27, 2017, 08:08:06 am
I’m doing 2.7 exercise of “next steps with rail clone”. The file is "ligne_roset_snowdonia_large_settee_vray".  I did the slicing both manually and using railclone slicer script with same result. Segment alignment set to “Y to Pivot”.
Question: When adding “default” segment, it does not fill all remaining gaps!
Title: Re: gaps when building components
Post by: Paul Roberts on November 28, 2017, 04:09:15 pm
Thanks for getting in touch. I can see from the attached files that there is a small problem with the source geometry. It would appear that the slicing operation has left some isolated vertices on the model, and it's these that's causing the spacing issues.
(https://content.screencast.com/users/Paul-Roberts/folders/Snagit/media/87ac44ab-309b-4347-b5b8-15d6bcb0eb7a/11.28.2017-15.06.png)
Delete these vertices and everything should work as expected.
Paul.
Post by: QM4272 on November 30, 2017, 08:25:38 am
very interesting point
thanks paul
