Author Topic: sloped brick wall  (Read 3236 times)
BJ2494
sloped brick wall
« on: November 16, 2020, 05:48:25 pm »
I need help with this:
I wanted to make a brick wall with spaces between them and with an inclination as it goes up in height
Thanks and sorry for the translation
Re: sloped brick wall
« Reply #1 on: November 17, 2020, 08:38:43 am »
I had a macro for this but can`t find it now  :o !
Give me a few minutes to build a new one.
« Reply #2 on: November 17, 2020, 10:40:38 am »
Here is the Macro. My math for Vertical Adaptive+Vertical Gap is not correct at the moment but I don`t have time to solve this right now  :(
Macro can work in 3 modes:
1. With the Wall Heigth parameter (Y Spline not assign).
2. With X/Y Spline (Y Spline is assigned and it controls height)
3. Clipping Spline > When Clipping Spline is assigned and `Use Clipping.Ext.Size`check box is ON. (If the Check box is OFF Clipping Spline will act  as ordinary clipping for the first two modes)
note; You can get some interesting results by exposing parameters and adding some Random/Arithmetic Nodes.
eg. I exposed the Z offset parameter and connect the Random Node set with values -3 to 3 and generate on SEGMENT. This will result in randomness for each brick...
Please let me know if you need more info about the parameters.
Best Regards
« Last Edit: November 17, 2020, 10:46:16 am by Dragan »
BJ2494
« Reply #3 on: November 17, 2020, 11:15:19 am »
Please MAX 2019
Thank you
« Reply #4 on: November 17, 2020, 11:21:15 am »
I`m using MAx2018.It should work on Max2109.
BJ2494
« Reply #5 on: November 17, 2020, 11:28:12 am »
sorry, Max 2017
« Reply #6 on: November 17, 2020, 11:39:00 am »
Sure.
BJ2494
« Reply #7 on: November 17, 2020, 01:09:19 pm »
thank you very much, great job :)
