Author Topic: Spline offset modifier connecting start/end  (Read 7971 times)
Crayox
« on: May 01, 2024, 11:50:54 am »
so I have a spline for the road and I'd like a two splines on each side for various things like fences, benches etc. Whatever option I use (distance and offset are 0) it keeps connecting my first and last vertex. I only use y transform to have a spline parallel to the original, I don't need double or anything like that. Any ideas?
Re: Spline offset modifier connecting start/end
« Reply #1 on: May 01, 2024, 11:53:59 am »
You could try changing the Mode to 3D. That should fix it. If you want the end, then leave the mode on 2D, but change the End Type to an open option.
I hope that helps,
Crayox
« Reply #2 on: May 02, 2024, 10:05:30 am »
Yes, thanks! Changing to 3D worked. Open option didn't for some reason.
