RailClone => RailClone Pro (*) => Topic started by: hubmer3 on June 01, 2017, 01:40:11 pm
Hy!
i setup au RC for a glass handrail, sadly the start and end doesn't fit to the spline.
what is wrong here?
thx
Just from provided screen-shots it's hard to say, what might be causing it. Please feel free to send us (http://forum.itoosoft.com/index.php?topic=3648.0) your scene to check it here. Thanks in advance.
I would suggest you to check if the size of used Segments isn't overridden under Segment's Properties - General - Fixed Size or any Transform - Translation isn't applied.
Best regars,
Hy,
i attached the file.
thx
It's related to the Pivot Point position of used Segments, currently used for the Alignment. That's easy to fix by setting the Alignment - X to Automatic for these Segments or by moving the Pivot Point to the "beggining" of these objects. Attaching modified scene, hope that helps.
