Author Topic: Glass Partition  (Read 6671 times)
hoshimiya@midasco.co.jp
  • Guest
Glass Partition
« on: June 19, 2017, 06:46:34 am »
Hello
I am trying to create glass partition system, but having trouble creating corners.
I am attaching image & max file to show where I am having trouble.
Any help would be much appreciated.
Thank you!
Re: Glass Partition
« Reply #1 on: June 19, 2017, 12:47:01 pm »
Adjusting the "Silicon" X Fixed Size parameter used for the Corner input to "GlassPanel" Y Size attribute should do the trick. Attaching the modified scene. Hope that helps.
  • Guest
Re: Glass Partition
« Reply #2 on: June 20, 2017, 10:32:53 am »
Thank you for your help, much appreciated.
But it is not exactly what I want to achieve. I might not be very clear at the first place. So sorry for that.
Can you have a look at the picture I attached?
I would like to have the partition corner as shown in that pic which I have trouble finding the way.
By the way I got the error opening your file. It looks like the style is working the way you designed though.
Should I download latest beta?
Kind regards,
Re: Glass Partition
« Reply #3 on: June 20, 2017, 03:36:46 pm »
Please find attached a sample scene (RC 2.7.4 compatible) with possible solution (in attached scene, Padding values are calculated automatically from used Segments, but it can be adjusted easily manually too). Hope that helps.
  • Guest
Re: Glass Partition
« Reply #4 on: June 21, 2017, 05:34:20 am »
Great!
Thank you for your help! I managed to get what I wanted.
Learned something new!
