Author Topic: Segment does not re-conform to terrain after transform randomisation  (Read 3562 times)
Alex.S
I have a transform node which adds padding and random translation. After this node my segments no long conform to the terrain. Do you have any solutions for this?
Re: Segment does not re-conform to terrain after transform randomisation
« Reply #1 on: March 16, 2020, 11:33:55 am »
Would You please attach the scene file ?
Alex.S
« Reply #2 on: March 16, 2020, 11:41:03 am »
Here we are
« Reply #3 on: March 16, 2020, 11:53:13 am »
You have set segments settings to "stepped". Please play with deform settings to Your desired result:
Alex.S
« Reply #4 on: March 16, 2020, 12:44:15 pm »
but we did not wish to bend the object, we just wanted to place it in the correct place with the pivot point on the terrain. If we bend the object then it's deformed out of shape. i realise this is getting into ForestPack functionality a bit, but it seems like it should be possible.
« Reply #5 on: March 16, 2020, 04:40:29 pm »
Then solution is not to use Padding on the segments.
You can compose Your segment with an empty segment with Your padding values:
Hope this helps
Alex.S
« Reply #6 on: March 16, 2020, 06:41:05 pm »
Ah so many ways to skin the cat, thanks :D
