Author Topic: Pan  (Read 2981 times)
Bobby Parker
Pan
« on: April 04, 2016, 09:13:47 pm »
I have a pretty large stone wall built and I have it attached to some surfaces, with boundaries. Everything is looking great, however, the pattern is starting and stopping at the same point, so I am seeing it repeating. I have a lot more wall to use, so I would like to kind of pan the wall around, inside the boundary. I hope this makes sense. In the photo, I would like to move one of the walls along the y, staying on the surface and using the boundary.
Re: Pan
« Reply #1 on: April 05, 2016, 10:18:43 am »
Hi!
You should be able to create this effect using the Clipping Area > Expand feature which enlarges the bounds of the array but does so inside the clipping spline so the overall size is not affected.
In the attached sample file I've added a Randomise Operator to this value so that you can quickly reseed the style to get different variations, I've also added a parameter so that you can adjust it on the Y axis after it's been enlarged in case it's helpful to further align courses.
Thanks!
« Last Edit: April 05, 2016, 12:32:54 pm by Paul Roberts »
Bobby Parker
Re: Pan
« Reply #2 on: April 05, 2016, 02:47:00 pm »
thank you, I'll give it a try.
